No, you can not piece together a passive horn setup. The only horns that will work off of the ID CS1.X passive xover are the CD1e's. If you go with the CD1Pro's or CD2Comps, you must run active which will require 4 channels of amplification for a 2-way fronstage (horns and mids) and an active xover. The IDX24 is an active crossover, which is no longer in production if I recall correctly.So that means I can basically piece it together and run it as a passive setup? Which mid would work best with idx 24 crossover? Something with excellent mid and midbass response and be able to keep up with the cd1pro is what I am looking for. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Like I said in another thread...I would avoid audiocontrol's analog pieces. Not user friendly at all and they don't allow underlapping or overlapping. You can try them if you wish, as they do allow 24db/oct slopes...but they use resistor packs rather than a pot for setting the xover frequency...which means you'll need a resistor pack for every xover frequency you want to try, and everytime you want to change the xover frequency you'll have to back there, open up the xover, swap out resistor packs, reassemble the xover, then go listen again. Rinse and repeat.Just looked at the IDX24 and thats nearing the 500 dollar range. I know ebay has the pyle and boss crossovers but, you suggested getting an xover under 100 dollars, which brand do you suggest? (ie audio control ?)
Yes, but the IDX24 + CD1 or CD2 + good mids > CS1.6 in terms of performance aswell //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifNow thats a lot. For $500 you can basically get the cs1.6 setup new.
