ID comps
id is also coming out with 6 and 8's heard that right from eric in kc
Well if you are mentioning things that are coming... We are coming out with dvc 4 ohm 6.5s with ~13mm of xmax and 94dB/w/m efficient -- yea I do mean per watt... not 2.83V //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif -- should be about 2 weeks till the preorder on that one.
The 8" will be a little longer... 4 ohm -- only 90dB/w/m efficient -- but looking at between 15-20mm of xmax -- doesn’t do as hott IB but still does fine -- you will just want to bring up the low end with some EQ... will be very **** good ported though... Magnesium cone -- should be good upto somewhere between 1.5k - 2k
I really just want a nice mid that will hold me over until I get a new car and from there I can really do some things with the horns.
I may just stick to the Ref's for the time being...
id has them already just not out already tested with said product, if you wanted ID 6 or 8 i am sure they could scrape some together...they do have them as that is what comes in the set (6's originally). its kinda hard to say something on paper is the best when its not even out yet and of course if alot of those drivers are that good they would be scooped up and used rather than being used for the sake of being different. thing is you can say "XXXX" person uses something and set it up cosmetically the same but alot of the higher end set ups use gates and circuits (which ends up costing more than the equipment) to achieve the end result. xmax isnt the end all be all either if it was the idw sub wouldnt be good at all and if you asked anyone that heard one or used one they are a pretty highly loved sub winning pro street in sq 8 yrs after they arent comercially avalible anymore. /rant
Randy Savage
Randy Savage
New York
GSteg
