Icons Power Hungry?
Workin for DBs
So i just hooked up my ssa icon 15 inch sub and it does sound very clean, deep, and low however I feel like it's missing some output. Don't get me wrong it's loud and sounds very good being loud but I feel like it could and should be more. I'm running it on a sax 1200d amp at one ohm...so about 1200 watts rms assuming I'm getting the best from my electrical and my amp. The box is 4 cubes tuned to 30 hz...
My car's electrical is all stock so is that maybe contributing to the lack of output or is this sub just power hungry and need a bigger amp?
ya,you arent getting close to 1200rms out of that amp with stock electrical...maybe half..to 3/4 if that,,you need power to make power...simple as that..get the big three done, and add a second batt,see if that helps,if not,time for the ho alt
I second what audiobaun said. I don't know if you'll be missing out on 1/2 your output, but you aren't getting 100% from the amplifier. Beef up your electrical (Big 3, optional better battery) and keep your voltage up. The build quality of the box could also play a big role in that, and sometimes it's just the car. All subs perform differently in different vehicles.
Okay well in a couple of weeks I'll try doing the Big 3 upgrade... and I've heard that the alternator is more important to change than the battery...
It's in a 2002 explorer v8, and I think the alternator is 130A but not too sure. I do have a dmm...
The box I built from the specs of the design off ssa's website for optimal ported which is 4 cubes after displacement I believe tuned to 30 hz. The port is 3.5 inches wide and I think like 26 inches long or something...my dad and I built the box built the box pretty **** well I must say, really the only problem is that I cut the whole for the sub in the center and it was supposed to be 2 inches off center but I doubt thats affecting much
I always do Alt. upgrade before I do batts but a 130 should suffice on that power. Do the big 3 and see how much that helps. are you getting headlight/interior light dimming at night when the bass be slammin? lol
Naw I'm not getting any electrical dimming haha but I'll do the big 3 in a couple of weeks...if my alternator seems big enough for my system would i need another battery?
Not knowing ur voltage is just asking for trouble..... Spend the 15 bucks on a Stinger meter and monitor from ur dash. But yes a batt would help stabilize ur voltage and running the power you are should be more then enough to help maintain a decent voltage..
Workin for DBs
Workin for DBs
San Diego
disturbed471985
