Iam Stumped
Naxis2k1
grade A whiteboy
//content.invisioncic.com/y282845/emoticons/omg.gif.05aa02c3095d6ce9338996654eca0863.gif ok guys iam stumped my 4ch power acoustik amp ceeps over heating and going into protection mode, the amp is not running a load it cant hadel it pushing 2ohms stereo. my thought is it has to be a bad ground ive tried several location all the same sh*t. i have yet to try running it to the battery, think i should?. i dont have a multimeter so iam shooting in the dark here. i also have a hint of alternator wine could this be a ground issue also?
PLZ HELP ME!!!!!!!
alt whine, either h/u ground or amp ground.
CHECK ALL WIRING !!! every wire ! if there is a short in the wiring it will def do this.
try it at 4ohms mono to see if its the impedance your running it at
PLZ HELP ME!!!!!!!
Alternator whine is a sure sign of a bad ground. If you haven't already, try making the ground wire as thick and short as possible and make sure you scrape the surface to which your equipment is grounded down to the bare metal.
Overheating issues can be another sign of insufficient ground, but this is most likely not the problem. Try moving the amp somewhere where it will get plenty of fresh airflow and maybe turning your gains down a bit.
If it keeps overheating and making alternator noise after you've made the adjustments I listed, you're likely the proud owner of a junk amp. On the positive side, they do make great door stops, paperweights and conversation pieces!
PS: Analog multimeters are only $10 at wal-mart. A very sound investment!
ok this is probaly a stupid question but i was told there are no stupid questions //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
anyways why do grounds have to be as short as possible? as long as its on a good ground plane i dont see why this matters. electricity travels so god dang fast anyway i dont see how a couple more feet of ground wire makes any dif.
it adds to the resistance along the ground path, not only will it cause some loss in voltage to your amp, multiple ground paths can form and noise will be introduced into the system
Naxis2k1
grade A whiteboy
Naxis2k1
Phoenix
Acidburn
NorthFramingham
    Jun 30, 2026
