Sold IA DP 15", Solid Audio F2500d, Kicker Hyperflex
seedubs1
(1) IA DP 15" D2
(1) Solid Audio F2500d
(5) VooDoo 1/0 to 4 awg inline anl fuse holders
(2) 5 meter kicker s-series interconects
(2) 20+ ft runs of kicker hyperflex 1/0
Incriminator Audio Death Penalty (IA DP):
D2 Coils
Run for 1 year on the Solid F2500d set to about 1.5kw with an O-Scope in about 4.3 cubes at 34hz
No rips or tears on the Surround/cone. Has been mounted and used, though. A bit dusty in the pics.
Mechanically 10/10
Cosmetically 9.5/10
Box:
double baffle braced with dowel rods. Screwed and glued. 4.3ish cubes at 34 hz. Strong and unfinished. Not the prettiest, but it gets loud and low.
Solid Audio F2500d:
Under-rated Korean made amp. Same Board as the AB XD3000d.
1600 x 1 @ 2 ohms
2500 x 1 @ 1 ohm
3200 x 1 @ 4 ohms strapped
4000 x 1 @ 2 ohms strapped
3s chipset, class D monoblock amplifier, Linkable, damping thd .05%, double sided epoxy, 24db oct var. crossover, subsonic filter, variable phase shift, 4 way protection, daisy chain through rca
Run for 1 year (original owner) at 1500W set with an O-Scope (No clipping)
Mechanically 10/10
Cosmetically 9.5/10 Has been mounted and used
VooDoo 1/0 to 4 awg ANL fuses
10/10 mechanically
5 brand new in box
Kicker S-Series Signal Cables
5 meters (16.4 ft) BNIB
Kicker Hyperflex 1/0
1 used run of about 20+ ft. in good mechanical condition
1 new run of 25ish ft
IA DP 15" D2 $300 in my pocket (will throw in the box for free, and it's a good one local pick up only)
Solid Audio F2500d $350 in my pocket
Hyperflex (2 runs of 20+ ft) $75 for the unused run and $65 for the used one in my pocket
Fuse Holders $10
Hyperflex Interconnects $20 in my pocket each
Doesn't hurt to offer if you can't afford what I'm asking. I'm firmer on some prices than others.
Local pick up on the sub. I'll drive as far as Indy from Columbus, IN. I'll ship it, but any damage or anything is on you. I HATE shipping subs.
Everything else is you pay actual shipping and packaging and PP fees.
REFERENCES:
Bought from: jaredspl, skip01, JbIrD, dman
Sold to: blackwaterOP, mrogowski, jadon087, plugitin, blazron22z, taintedplay, sleepyjr, wheelieking71, b12nismo, hrtbrk1, Lingerfelt, Kross6622, StickyFingaz
I know man, it's been a while. Got myself a real job and haven't had any time to get on the forums lately. Not to mention that I'd probably get fired if I got on one of these forums at work.
As for the Solid Audio Amp.....If I weren't getting completely out of car audio, I'd keep it. My favorite daily amp I've had by far, and I've had some nice ones (DD M series, Orion 2500d back when they were good, Crossfire VR4000d, you name it).
seedubs1
seedubs1
Indiana
seedubs1
