IA 20.1 RCA's Dead??
walkychalky
I installed my newest setup and everything was going good until i plugged the RCA's into the inputs on my 20.1 and got no sound. I had a problem with the RCA's coming loose from the circuit board before but never fixed it so i thought maybe the problem had just gotten worse. I tried re-soldering the connection but it still did not fix the problem. If i plug the RCA's into the input/ooutput for bridginfg i get sound but it is very poor and has alot of static coming from the signal. Is there any way to fix this? I bought the amp used a while back and it is no longer under warranty. Thanks!
cool, im actually looking for one of these...
I would think it has to be an issue with the RCA's somewhere...
yah im thinkin the the whole RCA block might need to be replaced....i jus dont want to go n do that n have it still not work
yeah, i wouldnt do that without experiance. Not saying you dont, but thats not to do for just anyone...
yah well my stepdad is an engineer who works on circuit boards for a living so id just have him do it.....but i'd have to go through the trouble of locating a replacement RCA block first
Are the gold plugs still on the rca input of the amp? Are they loose? A few of the newer RCA manufacturers have cables that fit so tight they are pulling the gold plugs out of our amps.
walkychalky
walkychalky
San Jose, CA
IA2
