IA 187 Qs???
Nova76
would two of these get loud on like 250 each i know its not alot but on the amp imna be using if i get these there D2s so i cant wire them to a 1ohm load so for now thats all they would be seeing untill i can get 2 more and run them off a hifonics 200rms amp so wpuld they sound alright or should i hook up 1 at 2ohm for the full 500rms???
yea the cone area was one reason but iv heared people running them with like 500+ rms and the sound great so i was just thinking 250rms less would that hurt the subs
o well i dont have anything to help set the gains i just set them by ear at listening volume is that bad?
No, not if you can detect clipping by ear.You'd probably be better off just buying a cheap DMM to be safe and make sure you're sending all the power available.
well i mean i have the settings all the way down and set the deck to negative as usuall for the bass and then turn it up to were i listen to it and turn the amp up little by little to where i like it its never usually more than half way up on the amp
It can be done that way, but like I said, you may end up with the gains too low that way. Easier to get a good estimate of where it needs to be with a DMM. "Halfway" may not be high enough, or it may be too high...there are other variables than just where the knob is pointing.
oh ok i got you my bad well how would i set the gains on a DMM iv never done it before
There is a tutorial in the amplifier section. Also, other tutorials can be found if you search on google. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Nova76
Nova76
Tucson, AZ
Nova76
