i think my amp is blown
matinm90
16
usa
okay so right now i have two kicker (4 ohms) cvrs 12 inch subs, they are each wired in a two ohm configuration, i have a sound stream pca2-360 amp, so for i just reconfigured their load resistance a few days ago, and i know that based on reading the manual for my amp that it is designed to handle two subs rated at 2 ohms connected to the amp, but for some reason, even if there is no sound coming through the receiver, the subs just make a boom boom boom sound, i have tested the subs resistance, and they check out perfectly, end when i gently press down on them they are normal, no weird noise or anything. whats really weird, is that if i manually turn off the subwoofer output from my receiver, the subs just keep going, but if i completely disconnect the rca cables from the amp, the noise stops, im thinking its the amp, any thoughts?
ill try that, but keep in mind that the subs just keep constantly outputting the same beat, boom boom boom, and it never stops, until i turn off the stereo which of course turns off the amp. and yes i have a multimeter. thanks for ur help in advance btw.
Is the amp hooked up 2 ohms per channel or do you have the 2 subs wired at 2 ohms each hooked up to the bridged channel? I need you to be a bit more specific about the wiring of your subs.
oh right sorry, so each amp is designed to be 4 ohms, but the voice coils are wired in parallel, so each sub is 2 ohms, and so, each channel on the amp receives 2 ohms from each sub. it is not bridged.
Take your multimeter and set it to continuity check(amp and radio off for this test is fine) . Is there continuity between the rca shield ground(the outer ring of the rca plug) on the rca cables and the ground wire for your amp. Better yet if you can easily get to the back of your radio is there continuity between the chassis of the radio/radios ground wire and the rca shields of the radio ? In almost every head unit the rca shields and the chassis of the radio/ground wire should be connected usually through a small internal fuse. sometimes this fuse blows and causes the issue you are experiencing.
okay but what u were saying before that is check the ground wire for the amp and ground wire for the rca cable right? and what do u mean by continuity?
okay I'll try that. But do you think it would help if I connected an RCA cable from my iPhone to my amp directly to see if it's the amp or not?
It would help rule out the amp. If it still does it with an Ipod connected directly to it then there is an internal problem in the amp. As far as continuity I mean you are looking for 0 ohms of resistance between the test point. I asked you to perform two test. First test take one lead of your multimeter and put it on your amps ground terminal or ground wire and take the other lead and touch the outer ring of the rca cable going into the amp. How many ohms are you getting? Second test you ate going to touch one lead to the chassis of the headunit or its main ground wire for the head unit and the other test lead will need to be touched to the outer ring of the rca outputs on the head unit. Again we are looking for 0 ohms of resistance between these points.
matinm90
matinm90
usa
Spooney
Mike Mccabe
    Jun 28, 2026
Giles
    Jun 27, 2026
