Bad_dude
The car: 1990 Honda Accord, 4 doors, Automatic. All stock and no physical mod.
The car audio components:
-Amps: Kicker IX 252 (2X25W RMS), PhoenixGold V752 (2X75W RMS), these ratings are at 4ohms.
-Speakers: Alpine Coaxials SPS-17C2, and Alpine Components SP600C. These are 6.5" round speakers.
-Head unit: JVC 7 band EQ with HD tuner. I have front, rear, and sub RCA output from the head unit.
-Sub: Tiny 6" Roadmaster Bassblaster.
-Crossovers: I got them on the amps and I bought 2 pairs of bass blockers, blocking 0hz to 5000hz for my component tweeters and another rear tweeters set. I read that my Alpine SP600C frequency seperation is not that great. This component speaker set does not come with the actual crossover but just the long cable attach to the cables seem to be bass blockers caps. So no actual crossover.
-Installation kit: I got one from Ebay a 4GA kit.
I got most of these for free. The only components I bought was the JVC head unit for $50 and the PhoenixGold amp clearance for $22. I don't have much money and I got to use these bit and pieces.
I need advice on 2 amps wiring, including fuses connection and locations. I also need advice on amp placements. This is my first time setting up with amps but I have installed many head units and speakers before. With my 2 amps installation, do I need a fused distribution block and a ground block? Or can I just split the power cable without the distribution block? And ground the two amps seperately.
I am thinking of setting up as follow:
The Kicker amp to my front Alpine SP600C components speakers with 2 bass blockers on the tweeters.
Using the head until internal amp to the rear Alpine SP17C. I will put an extra set of tweeters with bass blockers in the rear.
The Phoenix Gold amp to my tiny sub in the trunk.
I know the 6" bass tube won't shake any kidneys but it would give me some bass to help my music sounds heavier.
I also planning on running new speakers wire, 16GA oxygen free in case I need to upgrade in the future. Do I need to take the seats out to run the wire?
The way the system is right now, I got the head unit driving the front Alpine SP17C and rear JVC VS625 and that's it.
Thanks for any advice and help.
