I need an amp
Billybob1235
Michigan
I need an anp to run two subs (sony XS-L1235D4), I would like to try to get 300 watts to each. I only wanna spend like $350-$400. I've looked at the sony XM-3001SXD, does anyone know if that is a good amp?Does anyone have any suggestions?
Your subs are dual 4ohm soooo... if you want 300w a piece. You will need an amp that puts out that kind of power at either a 4ohm load or a 1ohm load. My suggestion would be the JBL BP1200.1. http://www.ugonet.com/jblbp12001.html .
600w x 1 at 4ohm. If you decide to upgrade later you can drop it to a 2ohm load and get 1200w out of it. Plus it's right in your price range //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
516
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
907
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
Billybob1235
Billybob1235
Michigan
n2audio
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
