i need a genius with
  • 6
Originally posted by paikiah marshall, you should learn to use WinISD pro man...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You can also calculate what the ssf level needs to be on winISD by checking the cone travel and if it goes over peak to peak xmax, that's where you need to have a ssf.(Maybe a little higher, to be safe.. dunno if the ssf cuts off at a steep slope or not, so...)
How come my winisd pro doesn't show anything when i select cone travel?
Originally posted by tommyk90 Well, i put all of the number i could off of the RE site, but do i need more than those numbers?
You need to know the power that your amp is going to send to your subs.
go to the "signal" tab... there, you will see W. that is where you input your amp watts. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by paikiah You need to know the power that your amp is going to send to your subs.
Alrighty. Put in 1200 watts, still got nothing.
EDIT: I think it's because i don't have all the parameters. I did the same thing with the L7 in the program and everything works.
yeah, I think that should be it...
peak to peak xmax, i thought it was one way
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
125
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
102
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
444
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
341
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
750
jbl_marshall21
important person
jbl_marshall21
nebraska
actlsub
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
