B150.2 Amp, Lightning Audio Bolt 2-channel, 50x2 @ 4 ohms, 75x2 @ 2 ohms, 150x1 @ 4 ohms - 450 Watts Max Power Type - RCA(pr) Voltage -.150-1.5 volts High Level
Per channel power - 50 W x 2 @ 4 Ohms RMS 75 W x 2 @ 2 Ohms RMS 150 W x 1 @ 4 Ohms Bridged RMS Total power - 100 Watts RMS Channels Crossover HP: 40-400Hz LP: 40-400Hz Tone Controls - Bass Control 6 db @ 50 Hz
Kenwood KRC-208S Casette Player
Full Bandwidth Power (less than 1% THD): 20 Watts x 4 Maximum Output Power: 40 Watts x 4 Auto-Reverse Transport Double-Guttered Tape Head Tuner Call During FF/REW Automatic Memory Entry High-Speed Multipath Control (RSC) with ANRC Kenwood CR-2 Advanced Tuner Station Presets: 24 (18 FM, 6 AM) Changer Control: 1 Attenuator with Smooth Volume Return: -20dB Disabled System Indicator Electronic Audio Control (Volume, Balance, Fader, Bass, Treble) Front/Rear Fader Iso-Mount Capability for Japanese Vehicles LCD Display Loudness Control Rear RCA Preout Removable Faceplate with Carrying Case
Pioneer GM X952 Amp
varies in continuous power rating from 40 watts x 2 to 100 watts x 2. All of the 2-channel amplifiers can be bridged to 4 Ohm mono to produce more power than the rated power specifications. The cosmetic design of the amplifiers also gives them an aesthitically pleasing look. Pioneer used a two-toned motif of pearl white with a gray fade for the heatsink and yellow side panels. The striking cosmetics were intended for displaying in amp racks as well as demo boards.
Hey I'll Trade you any of the stufff on here. for your amp I need a amp to Run 2 my RF HE 12's Please throw something at me. Thanks - Justin
Pioneer GM X952 Amp
