i need a 4k-5k amp
heres a bench result, try and make sure its a second gen or has the problems fixed cuase they had some issues
12 Volts:
4.6 ohms = 2279W
2.3 ohms = 3405W
1.15 ohms = 4188W
14,4 Volts:
4.6 ohms = 3042W
2.3 ohms = 4461W
1.15 ohms = 5358W
yea pretty impressive numbers, i found a guy whos willing to let 2 treo 1500s go for 900. idk if i should look into it u tell me. they do over 3k at 1ohm
Kinda up to you bud, I havent personally used em but I hear good things and I enjoyed my Treo subs, I could only assume if they make there amps like there subs you will like em
id take the z1 over the treos, altho ive never played with those... i do know the z1 draws less power then my 2 crossfire vr2000d's did.... and between just changin amps to z1 and sub to an up to an 18 i went up 1.8ish....
DDbump
TEAM D.O.A
DDbump
kenosha, wisconsin
bump - N - ugly
