I made my own sub enclosure...
  • 4
Brutus2600
Cleburne
and I don't know which way would be better to have wires running to the subs. Should I just drill a hole in the back and run the wires through, sealing it with some silicon afterwards or should I hook the subs up to some port so there are plugs on the back of the box. If the latter, how exactly would I do that? Like, what gauge wires should I use (they are 12" 300rms 900max subs) and where can I buy the connectors. Thanks!
If i was you I would use a connector at the backend of the box, you can use default "blocks" for it, i know the brands caliber and phoenix gold both have a component set for it which exists out of a golded block with a matching connector which you wire up from the inside, extention cables are mounted in the smaller golded connector which fits the backend connector, same goes for the speakerfeed connection. There's a small black thingie with two wire points on it which holds the fuse, its connected on one side of the power, ground and remote connector and connects on some points on that block.
The price of the caliber unit (called LGR-3 or sometin) in Holland is 87 euro. (euro, dollar is almost 1:1)
anyway, enjoy your project //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
can't I just like, 'extend' the connectors to the back? Like this I guess:
a) sub
b) back of box
c) connectors
Or would that not work for some reason? OR is that what you just said and I didn't understand it? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Pretty much what you have. Wire from the speaker to a terminal block and seal the terminal block to the box. The terminals are usually circular "cups" that force-fit into a 2" hole. Glue and sillycone the cup into the box. You can get them from Crutchfield or any other online audio source.
Or... drill a hole and run the wire out and seal it up with goop. It's really your choice.
Thats what I said //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif :) //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You can do both ways, personally I liked a connector on a sealed box better simply couz its the best way to connect it.
Your drawing matches the describtion i gave only i thought you had the amp build-in //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yes, what Dox said. The ++ -- makes it so you don't have to shove 4 wires into 2 connections. Convenient.
489
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
10
822
There is a good chance you could add some sort of Bluetooth or AUX input to a vintage stereo such as a 1978 Pioneer, maybe with a separate toggle...
835
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
985
Brutus2600
Brutus2600
Cleburne
ramos
