i know its prolly been asked before but i am too lazy to look today
Corsica
I have my ma audio XE 12" in the trunk. I wanna make it louder, and I know I can do it. I need each of the 2 channels to see 2 ohms from my sub. How do I make it do this?? If each channel sees 2 ohms i can get 150x2 rms which is just 50 below my subs RMS instead of the 100x2 @ 4ohm that i am getti ng now.
J
Originally posted by Corsica I'm sorry Dual 4 ohm.
J
how did you get a 4ohm load right now? dual 4ohm wired in parallel should give a total load of 2ohm.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by Corsica One coil to each channel............
J
that sucks..you an get some resistors to lower the impedence of each coil, but the resistor cost mucho deniero. over $200 each and i don't think they can handle the wattage of the amp that well. best thing to do is get another sub or stronger amp.
Originally posted by abcdefg this should give it a 2ohm load
So if i take a wire go from + to the other + and wire from one - to the other - and then run that pair of wires out and hook a pair to each
+ and- i will get 2 ohms per channel???
J
Originally posted by Corsica So if i take a wire go from + to the other + and wire from one - to the other - and then run that pair of wires out and hook a pair to each
J
you'll get a 2ohm load of only ONE channel though. that means the other channel would be left with no load. so you're going to get less power than before.
Originally posted by Corsica Lemme simplify, using 1 sub dual 4 ohm coils how do i get 2 ohms per channel on a 2 channel amp??
J
so you want each coil hooked up to each channel, and you want it too see 2ohm on each channel?
Corsica
Corsica
Ft Huachuca, AZ
Corsica
