I know how to wire it, but I just need to know to connect.
you just want all the positives together and all the negative together. does your amp have 2 or 4 spots for speaker wire? if only two then wire them just like that diagram, you will want to connect the subs together inside the box so that you only have 1 + and 1 - going to the amp.
Twist each wire up tight, then twist them together.
this.
the picture just makes it look confusing
i use these
http://www.hardwareandtools.com/invt/6110746
twist the positives from each speaker together then put them both in the positive terminal on the amp'then do the same for the negatives
ok! So I just cut off the plastic part of the wire, twist them together, put them in the amp, and hook them up to the subs like so. Then I hook the 3rd wire that goes from negative to negative,,,, positive to positive.... and just put them all there. I think I get it...
nickolas_j_t
I approve this message
nickolas_j_t
Midwest
nickolas_j_t
