I have to fix a halfassed install, help find the problem
Lakota
Doesn't Know $hit
The HU: Brand new Pioneer DEH-P7700MP
The amp: Ed NIne.1
The subs: 2 type r's dual 4's, wired to 1 ohm
Let's start off with the little entertaing story. I was supposed to install my friends system a couple of days after I told him that I would do it. Being impatient, he went ahead had somebody do it that thought they knew what they were doing, but had no idea. Here's the list of the things they did wrong.
-The power wire was hooked up to the battery ground
-The inline fuseholder was IN THE TRUNK
-The 2/0 welding wire (the power wire) was ran through the door jam and into the hood!
-The speaker wires that were hooked in the amp were not secure and small piece of wire were hanging out and were possibly touching eachother. This is also the same for the power and ground. (The fuses in the amp blew when they installed it)
-The ground was not bare metal in the trunk
The RCA's and remote wire were ran through the vent on the top of the dash, over the dash and throughout the car. Both the power wire and RCA's/remote wire were 100% exposed. Even the power wire was laying in the back seat!
Now that you've read about how ghetto the install is, it's time to see if you can help me narrow down the problem, which I think i know what it is.
I reinstalled the system for him, but the output is very faint. I checked over the install completely, and it was correct. The amp is fine, it works in my truck. The RCA's are fine, they also work in my truck. I measured the voltage of the RCA's in his car and it read 0 (which is why I believe the output of his subs were so low). I also checked the voltage of the amp in his car, it read about 12.5 w/ the engine off, so the voltage is fine. The preout for the sub is turned on on the hu.
Now my question is, could the preouts on the hu have went bad since the install was so ****ed up? This is the only thing that I can think of.
Disconnect one sub speaker wire...do you have more bass? if yes - one speaker is 180 degrees out of phase (as one sub moves out, the other sucks in canceling each other out) This is what happens when you wire one sub correct and the other has the +/-'s backwards.
As for RCA with 0 Voltage - did you measure in AC?
I know I measured in DC. I might have also done AC too, I can't remember. I'll try that.
for some reason he cannot understand what all of us are trying to say //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I'm just wanting to know what to do about it if it's out of phase. You didn't explain what that means and what I need to do about it. I was also thinking that it was a RCA problem.
Now I wish I would have put his box in my truck when I put his amp in:(
Lakota
Doesn't Know $hit
Lakota
Louisville, KY
Lakota
