i give up
Your volume is incorrect if those are exterior dimensions as you did not take into account for the thickness of the wood.
yea your right. i admit im a noob at this box building thing its a lot more complicated then i had thought. and i spent all my money on the sub and amp and only have like 65 70 bucks for supplies to build my own box.
Back to the forum now....
Man you have changed your dimensions 2 times now. I can help you out if you give your max dimensions and driver / drivers. What I got from your first post is the following:
Width= 23.00 inches
Height= 14.00 inches
Depth= 36.00 inches
Desired Tuning Freq: 34.00 Hz
Port Length= 20.07 inches
Driver Volume= 4.50 cu/ft
Port Area= 50.00 sq/in
Slot Vent Width: 4.00 inches
Driver Displacement: 0.18 cu/ft
Number of Drivers: 1.00 qty
Very rough, give me something to work with….
Man you have changed you dimensions 2 times now. I can help you out if you give your max dimensions and driver / drivers. What I got from your first post is the following:
Width= 23.00 inches
Depth= 36.00 inches
he's just a noob... try to restrain from killing him...
Width= 23.00 inches
Depth= 36.00 inches
add about an inch and half to all my dimensions and thats the maxx dimensions and the driver is a aqhd315.
95_venger
95_venger
demotte
c_hayhurst
