i did it!!!
traksta15
I love lamp.
i ordered my pioneer premier 2000spl's and all i need now is an amp. im lookin to spend between $200-$240 on ebay (new, buy it now), i've been lookin at the MA audio amps and they seem to be pretty well priced...can ya'll help me out and maybe suggest some more that fit in my price range...I would rather not buy from an individual but from a company. any help would be greatly appreciated.......
My bad on the ohms. You will want an amp that can push around 1000 to 1500 @2ohms 14.4 volts. This will make it harder to stay within your budget. Whether or not you have the dual 2 or 8 you can still obtain a 2 ohm mono load. Also remember that you do no have to have an amp that can push the subs to their rms rating, with the right box you can get full output with less than the RMS rating.
If you dont mind buying referb, go with it. Personally im not a fan of em though.
Why? They are checked before they leave the factory, so they are pretty much guaranteed to be in 100% working condition. Plus it comes with a 1yr warranty, just like a brand new product. So, basically, it's just like buying a "brand new" amp at a heck of a price.
Interlaced Carbon Fiber / Glass Fiber Reinforced IMPP Cone Woofer
Wide-Roll, 3-Layer Fiber Woven Radial Surround with Honeycomb Cloth
Double 4-Layer, Long Voice Coil (2 x 4ohm)
4-Slit Glass Imide Voice Coil Bobbin
Conex Damper with Damper Ring
Projected Pole Yoke with Vented Pole
Double Stacked Magnets (110 oz.)
Thick 7/8" (20mm) Top Plate
Aluminum Die-Cast One-Piece Rigid Chassis
Silver Binding Posts
1-Piece Rubber Gasket
750 Watts RMS/2000 Peak Power
Dual Voice Coil Design (2ohm or 8ohm)
Frequency Response: 18 - 2kHz
Sensitivity: 89dB (1W/1m)
Recommended Enclosure: 1.5 Cubic Feet
that's all it said on ETRONICS.COM
traksta15
I love lamp.
traksta15
Mcalester, Ok
btnhfan
