i can use a 2channel amp for a comp set right?
reed dollaz
all i need now is an amp for my comp set. would a 2channel amp work, or doest it have to be 4?
edit: ill be using the same power/ground from my last setup. 5ga power, 4ga ground. ill be fine with this on a comp amp, yes? im going to buy the knukonceptz 1/0 kit when im ready to redo my substage
thinking of doing just a front stage. if i leave my rears ill just power those by the HU, and fade about 5 or 6 to the back. since the comp set is only a 6.5" midbass and one tweeter, they shold be louder than my old pioneer 5 1/4's right? thats all the 5.25s aere, right. midbass and tweeter. this one will justbe bigger and amplified
actually the 4 chan i have would match ur sub amp and 85x4 would leave it open if u wanted to add something else in the rear or midbass or something hit me up if ur itnerested
ill let u know. im gonna go looking around town at some audio shops, see what they got. hate online transactions unless i absolutely have to. u know?
I would look for a 4 channel. You never know when you get an itch to upgrade later. It doesn't hurt the amp if you leave 2 channels unused. Just trying to save you money //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yea... know of one that does 125 x 4? 2 channels to my comps, and 2 channels to two tang band 8's im going to free air in my rear deck, cross over it w/ some tweeters and remove my 6x9's
reed dollaz
reed dollaz
Ocala, FL
reed dollaz
