i can hear my eardrum..
Could be a huge wax buildup, one time I thought I heard something in my ear, and it felt like something moved in there. So I grabbed a qtip and stuck it in there. When I pulled it out there was the biggest lump of wax on there that I'd ever seen //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
a gnat flew down my ear once, blasted it out with a bulb along with a brick of fallen wax //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
For a wax blockage the normal procedure to remove it is to take a large syringe and inject warm water into the ear canal to loosen and remove the buildup.
The syringe has no needle on the end, instead it has a tapered stainless steel tip. To obtain something similar check a veterinary/agricultural supply store and ask for a large plastic syringe the type used to give medicine to livestock orally.
A sinus/inner ear infection is also possible, the only remedy for this is to have a doctor look into the canals and check for redness and inflammation and prescribe the necessary antibiotic.
Placing a Q-tip into the ear canal can compact the blockage further into the canal and is not recommended, If you have any loss of balance/ headaches or soreness see your doctor immediately.
Permanent loss of hearing can result if you don't get this taken care of right away.
no seriously, i know what you are going thru right now...it happens to me all the time......just find a flathead screwdriver, unscrew ur eardrum and buy a new or used one off of ebay for around 20.00 not including shipping..... maybe you can find a bum on ebay that will take a 40 oz for his...good luck....
noob with an RS
i poop on you
noob with an RS
earth
icemike81
