I bought it
yeah...i've been wanting one for a while now. there was a pair on diyma with art in decent condition that went $100 for the pair iirc. those sold quuuiiicccckkkk. These are hard enough to find in near perfect condition. Only way i'd ever sell this would be with both ax400's. one ax400 is near perfect, the other is probably 8/10. these all should look like a huge *** a1200 once united //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
you bet your *** I will.
amps are mounted on top of my box. Im gonna have to drill a few small holes and run the wire up into the gap space since the space doesn't exactly have a place for wires to run out of.
to seal these small holes in my box regular home dept wood glue should do the trick right?
yeah the wood glue will work fine
the holes needed will be 2 8awgs and one hole for the rca run. Instead of making 2 large ish holes for the rca end piece, I'm going to make 1 small hole. I'll cut and recrimp some small wire to go through that hole, it'll be easier to seal.
BassAddictJ
BassAddictJ
FL
05fronty
