Hybrid Audio Technologies Legatia L8 8.5" midbass drivers
The Legatia L8 is a 215mm (8.5-inch) subwoofer/midwoofer driver. The Legati L8 is a cone-type driver consisting of a treated pressed paper diaphragm with low moving mass for fast, transient response. The cone design offers a wide dispersion pattern to make for flexible installation and speaker location. However, because of this driver’s specific design function as a subwoofer and midwoofer in expanded three- and four-way designs, its bandwidth was purposely left more limited than that of its smaller siblings. However, some may endeavor to incorporate the L8 into a strict two-way design with a large-format tweeter placed close to the same location as the L8, or used in concert with the wide-bandwidth L4 midrange.
Legatia L8 Thiele-Small Parameters:
Overall diameter: 215mm (8.5-inch)
Mounting depth: 92mm
Bolt Circle Diameter: 195mm
Mounting hole: 185mm
Pnom (without crossover) 75W (AES Standard)
Pmax (without crossover): 150W
Pmax (with recommended crossover): 250W
Frequency range: 40Hz – 2,000 Hz
Sensitivity: 87dB (2.83V/1m)
Mms: 31.5g
Cms: 454 um/N
BL: 5.99 T*m
Voice coil diameter: 35.55mm (1.4-inch)
Impedance: 4 Ohm
DC Resistance: 3.4 Ohm
Fs: 40Hz (free air)
Qms: 7.35
Qes: 0.693
Qts: 0.765
Xmax: 8.5mm (one way)
Vas: 26L
Sd: 0.02 m2
Excellent 9.9/10 only because they are used
300$ shipped
I WILL CONSIDER TRADES FOR FOCAL TN53K TWEETERS AND OR A JL 600/6
Will ship anywhere in original boxes. Located in Toronto
I have a few other items im putting up due to me not starting a new build, let me know if your interested!
Audison VRX 1.500 amp (2) available - 850$ea
Boston acoustics pro series 6.4x crossovers - 50$
Fusion Powerplant PP-SW12H 12" subwoofer -100$
Eclipse sw9122 *coil blown* - 100$
Mms: 31.5g
Cms: 454 um/N
BL: 5.99 T*m
Impedance: 4 Ohm
Fs: 40Hz (free air)
Qms: 7.35
Qes: 0.693
Qts: 0.765
Vas: 26L
Sd: 0.02 m2
300$ shipped
