Huge Question- What Order
tsaintw
Hey guys hopefully I caught you attention. I was just curious since I'm getting a new amp/front speakers/sub/head unit- what order should i purchase these in? I was thinking Head Unit-Speakers-Amp-Sub?
Let me know- also my current front speakers are blown/ not sure if this changes the order.
This is what i'll be getting by the way if you were interested
Reciever-
Clarion CZ500-$128
Alpine CDE/cda
Alpine IDA-X200
Clarion cz300
Speaker-
CTX65CS - Image Dynamics 6.5" Component Speaker System-$135
Woofer-
SSA Shop - SSA Dcon 12D4 subwoofer300rms
12" SSA DCON 12D4/S4-$125
Amp-
Audio Savings | CADENCE F600-4 1400 WATT 4-CHANNEL CAR AMPLIFIER NEW
Cadence F600-4 1400 Watt 4 Channel High Power Car Amplifier-$130
It doesnt matter what order you buy it in, i would HIGHLY suggest installing all of it at the same time tho. if you install the hu first your gonna need to take it out later for the rca's and remote wires etc.
tis all personal preference, and depends on your setup. to me I'd I'd go for best sound soonest, you need bass for good sound either 4channel amp and subs or 2 channel or whatever. Hook up the subs use your factory deck and speakers for now, then eventually get replacement speakers, and then a HU. just my $.02
Of coarse as noted above if you do things in this order it requires a lot more work. If you are going for the least possible work then I'd get at least your amp and HU and wiring kit at the same time, install the HU and the amp or at least get the wiring kit for the amp and run the remote and rca's so you don't have to pull it back out later. Then buy some subs, and last but not least speakers.
tsaintw
tsaintw
Bristol,RI
i2ain2thunder
