HU with most features under $300
U can pick up a higher end pioneer off ebay for less than $300 and have a ton of options to mess with. 760 premier would be a good choice, has mp3 capabilities. If you would like to stick with pioneer.
8600 on ebay is goin right at 300 and then plus shipping which was like almost 30 bucks. the 760 was only in the 230 price range and plus s/h
*edit* The 8600 is goin for $300 +$30 s/h=330
The 7600 is goin for $200+$30s/h=230
$100 difference on ebay and as stated under $300 which the person might be able to go above that but I'm just trying to help. Not to start an arguement on which one is better
it's worth it save up an extra $30 and get the 8600. i use to own a premier 750 and the 8600 is by far better then the 750 which is pretty much the same as the 7600
Not the most features, but I'll sell it.
I have an Eclipse CD3434. Everything for it - manual, box, harness, remote(numbers got smeared because I had f/b resin it so I tried acetone. smeared a little.)
I'll sell it for $215+ shipping.
*edit*
* DIN Size Chassis
* LCD Display w/Contrast Control
* Full Face Tilt
* ECLIPSE Security Network (ESN)
* Audiophile Components/Parts
* Integrated Optics Pickup Unit
* Full CD-R/CD-RW and MP3 compatibility
* CD Changer Control (Daisychainable)
* Digital Servo System (DSS)
* High-Voltage 5v(2.7v) & Low-Impedance 55ohm Output
* 3 RCA Pre-Amp Outputs - Front, Rear & Non-Fading
* Electronic Crossover Control
* Remote Control
Power Output
* 200W MOSFET Amplification (50watts x 4)
CD Features
* CD-R/RW Compatible
* Track Scan
* Track Up/Down
* Fast Up/Down
* Repeat
* Ramdom Play
Tuner Features
* ECLIPSE STARTUNER V
* 24 Station Presets (18FM/6AM)
* Preset Scan
* Auto Station Memory (ASM)
* UP/Down Auto Seek
* One-Touch Station Memory
* Auto Local/Distant Seek Sensitivity
Audio Features
* Independent Bass/Treble Memory for each Source
* Balance Control
* Fader & Pre-Amp Fader Control
* Loudness
* Mute
http://www.eclipse-web.com/products/cd/cd3434.htm
*edit*
* DIN Size Chassis
* Full Face Tilt
* Remote Control
Power Output
CD Features
* Track Scan
* Track Up/Down
* Fast Up/Down
* Repeat
* Ramdom Play
Tuner Features
* Preset Scan
* UP/Down Auto Seek
Audio Features
* Balance Control
* Loudness
* Mute
IMO this is the best choice...Although theres a typo on the voltage preouts. Theyre only 3V @100Ohm
--Don
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
I'm actually lookig at the manual right now and it even staes that it's 5v @ 55ohm.
My guess is it is a typo. It is a "3" series deck so it has 2.7V/300 ohm pre outs(I think Eclipse has the best pre outs, top to bottom, in the business). The spec sheet on their website indicates 2.7V as well.
I would take a 2.7V eclipse over many "4V" decks from other companies.
To the original poster....you do realize "most features" doesn't necessarily equate to "best," right?
The real question is, what do you give up for those extra features ? ...
exactly... why are you kids so obsessed with bling and features on POS deck. to the inexperienced, any good you could do with those features is actually used to screw the signal up some more. get an actual good transport and you'll even spend less
icemayne696
ngsm13-Douche Drinker
icemayne696
FL
mudd
