HU problems...
Anonymous User
****** FTW!
I have a Pioner Premier DEH-P470MP, i couldnt find a harness for my van [ that doesnt have the data bus II ] locally. so i tried tapping into the stock harness with quick taps. The deck turns on, but when i tapped the speaker wires there was no output. I tapped into the same wires i used for tapping my LOC into my stock deck.
What could be the problem?
you got certain wires mixed up, positive and negative. were you able to use your balance and fade feature on your stock deck and have it effect your subs?
what i remember from the top of my head is that my stock deck didnt effect the sub output unless i changed the Balance [ left to right ] not when i messed with the fade [ front to rear ]
well if everything was correct it should have shut your subs off with your fade all the way to the front, or if you wired it backwards all they way to the back
i know that....i was just trying to get at that my stock speakers dont work when i tap my stock harness with my pioneer harness together using quick taps.
well...i tried something.
I hooked up both my pioneer & stock deck at the same time. And the pioneer would only have sound out to the speakers when, the stock one was hooked up & not plugged in.
what could make it so the pioneer would only have outputs to the stock speakers, when the stock deck was hooked up but not on?
Anonymous User
****** FTW!
Anonymous User
Bay Area, CA
Anonymous User
vegang
vegang
