HU issues. need input.
  • 2
miker
Wayzata, MN
Well. I have a Sony HU that I bought from CC (With a warranty)
Anyway, I have had it 4 months now. As of a week ago my speakers started cutting out randomly, and there was crackling noises coming from them. So I check all the connections, make some "iffy" ones better, and still the problem continues. Then one day I pushed on the face of it while my right side went silent, and it started working. I try this everytime it gets funky, and everytime I push it, it goes back to normal.
So, whats up? My speakers are all amped, so they are connected to the HU through RCA's.
The HU has a flip down face b/c the CD played is behind it.
So, is it my fault? Or should I request a new HU from CC since I have the warranty.
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
374
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
miker
miker
Wayzata, MN
miker
    May 12, 2024
Brendon Jenness
    May 11, 2024
