ToxicBanana
Ok, so as I understand it. Audio crossovers are a class of electronic filters designed for the purpose of splitting the audio signal into separate frequency bands which can be handled by individual loudspeaker drivers.
Now that being said, the Pioneer DEH-P880PRS has two preout options.
1) (normal) Front, Rear, Subs
2) (3 way network) Tweets, Mids, Subs
I bought a HD-62 a few years back but the Mid was upgraded to a ES-07 7" Mid/Woofer. so would that make the crossover not perfectly made for this mid? and wouldn't I be better off with the amp powering the tweets and mids independently?
HD-62US Set Specs.
Midrange: 6.5" Cast carbon treated.
Mounting dept: 2 3/4”.
Crossover: ES-200US “Transient Optimized” Elliptic 4th order 2-way with Built-in UpStage design.
UpStage Ready!
Power handling: 200 watt RMS @ 100Hz High Pass.
Frequency response: 65-20kHz.
Sensitivity: 92.6 dB.
Impedance: 4 Ohm.
Main tweeter: DRT-25 extended range 1” silk.
7" Woofer Specs
Diameter: 7” (180mm)
Sensitivity: 92.2 dB
Power Handling: 100 Wrms (200W pk) (IB) // Sealed (200rms+)
Frequency Response: 50 ~ 5000 hZ
Nominal Impedance: 4 Ohms
Voice Coil Diameter: 1.5” (38mm)
Dimensions:
The Amp is a Rockford Fosgate 1000 25 to Life.
Birth sheet is.
4ohms = 108Watts X 4
1ohm sub = 956watts.
HD-62US Set Specs.
UpStage Ready!
Impedance: 4 Ohm.
7" Woofer Specs
Dimensions:
Birth sheet is.
