How would this setupt do?
plus i drive a jeep, i dont need to be "heard" a block a way, i can be seen.
LMAO......I like that response. That's awesome //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
Anyways, you can find the Ascendant Atlas here: http://ascendantaudio.com/Atlas%2015.htm
The "ohm" (aka impedance //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif ) is important for matching it up with your amp. You don't want an impedence below what your amp is stable into. So, for that amp, you want to be sure you end up with a sub that has a 4ohm impedance (which, the Atlas does have //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif )
yeah.. and also, if youre looking into dual voice coil woofers, then get a dual 2 ohm woofer. that can be wired to give you a final impedance of 4 ohms. most single voice coil woofers are 4 ohm woofers, so those are fine, but most will probably be DVC.
well you got 450watts at 4ohms.
Why a 15, why not a 12? I say a IDQ 12 or Alpine Type R 12. About 100-150 on ebay, port it will be nice.
But if you want a 15, maybe ED K 15 or O series.
Something from RE?
Something from RE?
why NOT a 15? more cone area (more spl), usually lower extension, and sometimes more power handling than a 12 of the same model
Yeah for a cherokee i think a 15 would do well, i mean yeah i debated between 12 and 15 for like 2 weeks and im still not 100% sure, i just want best for my amp yet still in price range.
i'll look into the atlas mos def
Jhyde00
Jhyde00
Michigan
Jhyde00
vegang
vegang
