how would i wire this?
  • 2
hiloracerboy84
how would i wire 2 infinity perfect 12's to a jbl 1200.1?...i want to run a 2 ohm load, so the amp puts out 1200 rms, which will be divided between the two subs. is it even possible to wire the two subs off of the amp...cause its a mono amp right?...
thanx in advance;)
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
154
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
679
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
924
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
899
hiloracerboy84
hiloracerboy84
san jose, CA
EPanther99
SPLBassJunkie
    May 21, 2024
    May 20, 2024
