how to wire tweeters?
Where do all the helpful people go? //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
Seriously. Um...here I will make it like this..
What is the "High level input" For?
How can I wire the tweeters off of 1 - and 1 + output from the battery?
Thanks.
dude you got it all wrong. the power and ground on the amp go to ur speakers. + and -. then ur speaker termninals wire up to ur batt. then u pour some grape fago on that bad boy to help it stick to the box..... DUH!
sounds to me like you want to wire tweeters to the same amp as your sub.... which won't work.
thats correct....he has made multiple threads and we told him he couldnt in the other one...but he is hard headed and wonder why people are not helping...//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif//content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
How many watts does that battery put out?
this is sig worthy
well i got two +/- and L/R outputs on my amp. Im already using one +/- and LR for the bass tube. So I guess I got one + and - / L and R left.....can I some how use that to wire both tweets or do I only gotta have one tweeter?
Well thanks guys.
Just to let you know: I tried to tie the wires together...eh......+L output speaker wire pretty much wrapped around the end of one of the tweeters (stripped wires wrapped together) and the -R same way to the other tweeter. Turned it on. Didnt work (as Im sure you guys know, or should it have? ) then, I tried wiring both the +&-/L&R output speaker wires to just one tweeter and pretty much wrapping the stripped wire together. Didnt work.
So, I cut the wires, disconnected and gave the tweeters to a friend.
Im not gonna get mad at you guys cuz I couldnt get help without you (not that I did get help) but...if you werent here thered be no chance anyway. I know you guys were suggesting I do something else, which probably would work and be better. But I dont wanna take power from my components or get into that kinda wiring and panel removing....oh well, I guess Ill stick with Low bass.
Just letting you guys know how it turned out...for now...I give up on tweeters. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Well thanks guys.
that sux it didnt work:wow:..........but yeah the only way to do it and get it to work is how everyone suggested....not everyone is trying to be dicks but you just kept at it when we all said it wouldnt work....gl
if you want to wire tweeters to your amp you have to get caps which only allow high frequency through or you have to buy a new amp and set it to only high frequency.
Foote
Foote
Horn Lake, MS
Bassin Buick
vegang
vegang
