How to wire in a center channel speaker
  • 6
smug_gxp
In my Grand Prix I have a spot for a 3.5 inch center channel speaker and I want to use it. My system includes a Pioneer AVIC Z2, Kicker 10ZX700.5, Infinity kappa sub, Infinity Kappa 6X9 in the back and Infinity Kappa 6.5 componets with tweeters in the front. I am kind of afraid to bridge a center channel speaker on the front channels of my amp because it might drop the ohms to low. I was thinking of using my headunits internal amp for just the center channel speaker but I am not sure what is the best way to wire it up. What do you guys think??
I wouldn't do that. A 5.1 system is for HOME theater not car audio. Unless you plan on watching a lot of movies in your car (which is retarded).
I believe you will need a prossesor to get 5.1. bridging it will just be a left right combined mono signal.
I use a eq that has a center channel out.
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
147
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
676
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
922
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
897
smug_gxp
smug_gxp
Grant Park, IL
Louisiana_CRX
    May 20, 2024
    May 20, 2024
