How to Wire Additional Accessories?
Shelbrain
I am preparing for an upcoming wiring project in my Impala and was wondering what is the best way to run additional accesories in a car.
For example, I currently have a radar detector and an XM tuner that need to be hardwired. The XM tuner is the Alpine TUA-020XM (has yellblk power connectors) In the future, I may want to two additional screens for the headrest. Where do I pull all this power from?
According to the Peripheral GMCO I am going to purchase as my wiring harness, the instructions I read say not to use the 12v acc in the harness to power anything other than the radio. Where else could I pull power from? According to everything I read, this car does not have an acc wire, that is run through the databus.
It does have an accessory wire; it just doesn't use the accessory wire to control the radio. You can tap the brown wire behind the key switch if you just want key-controlled accessories. The XM tuner needs a constant power source so you can tap that one behind the head unit. If you want other accessories to be controlled by the radio power, do as azbass said and use a relay controlled by the head unit's remote output wire.
So I tap the power wire behind the headunit for the XM tuner? (just double checking) and then I use a relay from the 12v acc wire to run my accessories and for my remote turn on lead?
Yes, connect the XM tuner to the YELLOW wire behind your head unit.
As for the other accessories, do you want them to be controlled by the key or by the head unit? If you want them to turn on/off with the head unit, use the head unit's remote wire to activate your relay. If you want them to be controlled by the key, use the key switch accessory wire instead.
@KaeZoo (or anyone else): So if I go the relay route, can I just run one wire to the trunk and tap into it 3-4 times to power all my accessories (XM tuner, remote turn on, etc.) using the single output wire of the relay? Or is there a distribution block method which uses smaller power wires (16-18 awg) typically used for accessories?
Yes, you can run one wire back and tap everything you need into it, with two caveats: The wire has to be able to handle the current draw of all your accessories, and so does whatever you use as a power source (connected to terminal 87 on the relay). Depending on where you make the connection, you'll probably want to fuse this wire. If you want to be neat you can use a barrier strip with jumpers to make each of your accessory connections in the trunk.
Note, again, the XM radio unit needs to be connected to CONSTANT power, not switched power.
Do you have a link to a barrier strip you'd recommend? I am officially going to be doing the install the week after Thanksgiving so I am hoping to keep the friendly advice coming when my car is torn apart :)
Shelbrain
Shelbrain
Florida
Shelbrain
vegang
vegang
