How to Properly Coil Cables (Tutorial I made)
Megalomaniac
Mr.SQ
How-To “Over-Under” Looping Cables
The most common mistake I see almost everyone make is coiling a cable. I will be showing an easy How-To on how to coil a cable (any cable) properly. I will explain and demonstrate the wrong way of coiling, right way of coiling, and why it is important to keep them cabled properly. Coiling a cable properly will keep the cable in shape, fresher, easy to dispense, and lasts longer.
The wrong way to coil but yet the most common way of coiling is over and over looping. By holding cable in one hand, and wrapping around elbow. This method is wrong for several reasons.
1. It creates a Kinks and Twists resulting in a deformed shape and a damaged cable, it can create signal loss from resistance
2. It gets tangled easier
3. When you get ready to use this cable its all out of wack and you waste time trying to untangle it and straighten it properly.
This is the proper way to coil a cable correctly:
Step 1 to properly coiling is to hold one end of the cable in your hand (doesn’t matter which hand, usually if a male and female end such as an XLR cable you would hold Male end in hand)
Step 2 is to make an Over loop going clockwise with the cable making about a 1 foot diameter
Step 3 make an Under loop by grabbing the cable about 2 feet from your right hand and bring the cable (left hand) towards your right hand and twist your hand 180 degrees clockwise as you are bringing it in.
It should look like this when you look at it profile style:
Step 4 Make an Over loop, grab cable about 2 feet from right hand with your left hand and loop it over your hand like normal, no twisting ( same as step 2).
Step 5 repeat step 3 and 4 until cable is completely coiled
Step 6 Tie cables tie to it and hang the cable up or store it safe. Cable ties are cheap, buy them.
Step 7 when you are ready to use simply untie the cable tie and hold one end and throw the rest of the cable, your cable should stay straight and tangle free.
Comparison cable throw demo
Coiling a cable properly is easy to do and can be somewhat time consuming at first. But once you get the hang of it you will make it a habit to coil it like so. Your cables will last longer (saves money), stay in shape, tangle free, and it is easy to dispense when you need it for the next time.
nice tutorial. I'll have to admit when I read the title and then say your first pic I didn't think it was going to turn out well, but I see you were showing the right way and wrong way (first pic) Cables are soo much easier to deal with when they are trained properly and wound up properly after each use.
Nice outfit.
everybody always be commenting on that...//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
i like what I wear. so if its a complement thank you //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
lol yeah
hmm. i had to spend about 20 minutes the other day untangling wires that i didnt even realize have been getting worse and worse....but im just too lazy to tie them up usually.
its not about tieing them up that is just for convenience you want to coil them properly //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Sweet mustache //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
lol you must have saw my before pic when i just had a beard..no mustache with it.
Megalomaniac
Mr.SQ
Megalomaniac
The Colony, TX
iagrdshaka
vegang
vegang
