How to mount subs in a box so they can be easily removed
Hi all,
I am mounting two 15s in a sealed box I've constructed. I forsee that I will need to remove the subs several times (in order to add filler, replace subs, etc, etc) and I want to somehow mount the subs so that I can repeatedly screw and unscrew them. I dont want to have to redrill new holes and rotate the sub everytime I service it. What is the best way to go about this?
Thanks!
Use anchors and machined screws...you'll never do it any other way after trying it once //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
And cover the insert nuts in JB Weld before hammering them in...they wont ever budge..
T-nuts and bolts will be the best, but just typical wood screws or drywall screws work for that unless you can't control yourself with overtightening/stripping them out of the wood
Threaded wood inserts work best IMO.
With T-Buts, they tend to not grab very well, and the teeth break/bend. Then when you try to take the bolts out, they just spin. In my experience anyways.
I think he means... he will be taking the screws out a lot, and doesnt want to strip the holes.
//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif lol didn't think about that... //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
i have a double baffle, and use #10 sheet metal screws about 1 1/2" long. ive had my sub in and out of the box about 10 times and ive nevers striped the holes, but i dont screw the shit outta them eather, just enough to bite
2006xplorXLT
2006xplorXLT
Roanoke, VA
406er
