How to hook up my speakers to my amp?
bones justice
i have the Power Acoustik Gothic 800 watt 4 channel amplifier
85x4 @ 4ohms stereo
105x4@ 2ohms stereo
210x2 @ 4ohms mono
i have the following speakers for midbass, midrange and highs:
1 pair of Eminence Beta 8" Midbass Speakers (8ohms )
1 pair of power acoustik bullet tweeters ( 4ohm )
1 pair of hollywood sound labs components ( 4ohm )
how do i hook up the speakers to the amp for best results?
300
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
bones justice
bones justice
Los Angeles
jmoreno150
