HoW To GeT To ThE BaCk???
I dont know how your backseat is constructed...
You have to look at it, poke around.
Pull on the bottom part of the seat back by the seatbelt inserts, try to pull it out. Look for bolts. There might be insulation... I don't know. Best thing you can do is assess the situaton, try to find a path for the wire. Stuff your hand up there. Look at both sides of the seat.
There is... i think you can get the wire under it though, but you might have to push it up the back of the seat and out one of the holes. My Crown Vic had a foam padding stuff I had to cut to get the wire through.
That's what I was getting at. If you can feed a wire from the trunk underneath it. Then you can just tape your wire to the wire you pushed from the trunk and pull it back through. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Have you removed the bottom part of the back seat yet? In order to do this you have to release it from the clamps that it clips into (in the front). To do this just push down and towards the rear of the car on both the drivers and passengers sides and then lift up. After you have the bottom part of the seat removed, there should be a gap under the upper part of the seat for you to run your wiring through.
audiobahnuser18
audiobahnuser18
Mi
DiamondFanatic
NorthFramingham
    Jun 30, 2026
