how to get internet hack on iphone
pioneerpimp
does anyone know how to get the 5.99 tzones package on an iphone but get the full internet plan for 5.99 instead of 19.99? i know there is a way to do it but i googled it and came up with nothing concrete. thanks for any help.
2.1? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
well, it needs to be jailbroken so you can A. either download the hack from the installer you get from jailbreaking it, or you will have to SSH iinto yur phone and add a .txt file that has the code written in it to unlcock the "server block" on the tzones plan.....your best bet would be to downgrade firmware to 1.1.4....thats what i used and the hack worked great.....except after awhile tmobile catches on to all the data being sent over their "tzones" network and they shut you off.....or they shuut me off anyway.....havent tried again sicnce but it was awesome while it was working......maps google you tube everything worked ANYWHERE. t mobile knows about this hack so idk if it will even still work....
she has Modem Firmware 04.05.04
at least thats what it says. version 2.2
and yea t mobile has no more 5.99 tzones plan. will it work with any other cheaper data plans?
it may work on other data plans.....it all depends on if the data plan has the main HTTP ports for the "internet" unblocked...the reason you needed a hack for tzones was because it blocked the main ports of basic internet sites....(port 8080 or something like that i forget) what carrier do you use......that would help
Thanks man. I'll play with it later...
Thanks again.
Chris
pioneerpimp
pioneerpimp
IL
chase007
