throw 5 or 6 coats of clear on it, then wax it, mainly to protect it and keep it shinny.why use wax when you can put a clear coat on top that lasts longer?
Only problem with using clear is the price adds up real fast if ur using a good clear coat. If its not gonna be in the sun (ie in the trunk of a car, or protectec by really dark tinted windows. U would be fine with just compound.throw 5 or 6 coats of clear on it, then wax it, mainly to protect it and keep it shinny.
I perfer my way, 8 coats of clear and high speed buff it (not orbital) with the edge yellow pad (medium cut) and some machine glaze, then throw some carnuba wax ontop of that.
well sanding it good and painting it really good.... should do the trick....i already did that but people keep suggesting i put a top coat of fiberglass resin
There really is no point in resin. If you prime it well enough, it will be sealed just fine and take paint very well. Resin could be a ***** to get sanded down just right.i already did that but people keep suggesting i put a top coat of fiberglass resin
beautiful.Depending on the color you are going for, you could consider using a laminate...its definitely a lot easier. If you want a gloss black, or a common color. My sub box has black laminate on the face (behind the silver trim piece which is painted):
