How to fix sunfaded door panels
I figured what I can do is sand down with maybe 300 grit...get some SEM advesive promoter, texture paint, and the other paint and try to fix it.
I am also going to call this upholstry shop to see if they can fix them.
if its scratched, then you might as well re-paint it.
sand it a lil with fine paper
spray with adhesion promoter
primer in the can
then paint in the can...then a clearcoat for shine if wanted.
It spretty simple and everything is found at autobody shops. They can match colors too.
You're on the right track, use 220-300 grit to rough up the surface, clean down with rubbing alcohol, primer, then paint.
Flipx99
Violator of Terms
Flipx99
Building 100
Flipx99
