audioholic
not a moderator
Many bass knobs these days are simply a gain limiter, meaning all the way turned up it simply allows the amp to output full power according to gain settings on the amp. But most people associate bass knobs with a 'bass boost' function. Im not familiar with that particular amp to say which type it is however.
Your voltage numbers do not indicate a significant voltage problem to warrant the amp shutting down. I guess I should ask, when you say the subs 'shut off', does the amp itself turn off? You said it does not go into protection mode which would seem to indicate you are suggesting the amp stays on. If that's the case, Id look elsewhere for the problem.
