How to fix a small tear in surround?
kingsxman
Noob in training
Picked up a pair of 10" JL Audio W6v2's today in a sealed enclosure. ($225 out the door by the way). One of the surrounds on the woofer has a small little puncture/slice in the surround. Maybe an inch long. Can tell when you press on it that it is weak there slightly.
First off, is this affecting the sound much?
Second, how do I fix it? Is there some sort of poly that can be applied? I hope I'm saying where it is correctly, I think its the "surround", which is the raised rubber piece that goes around the outside of the cone.
Or clear silicone sealant, use a q-tip from the back side, and don't use too much, if you doo it will make a stiff spot in the surround. Stab it with a power screwdriver when you put it in? Don't feel bad, pretty much every one of us here has done that at least once.
Yep, I bought it with the tear. I honestly didnt even see it. Someone from the pawn shop I bought it from mentioned it as they were wringing it up. Its really really small.
Is it affecting the sound as is?
i got lucky and it was an inch scratch/dent in the cone lol
kingsxman
Noob in training
kingsxman
Minneapolis
btnhfan
