1hawaii50
I need to install a relay on my 12v switched line as with the ignition off, I'm getting 5-13mv "bleed-through" on the line and it is causing a problem with my PAC SWI-PS. I want to install a relay and use the 12v switched line to "trip" it, but I need to make sure that the relay will "turn off" when I turn the key off (even though the line is still seeing 5-13mv). I checked Radio Snatch, but the idiots working there had no idea at all. Autozone is also clueless. I found on bcae1.com that a "typical" bosch relay closes at 8v and releases at 1-5v. This doesn't help me as I don't know if the relay at Autozone is the "typical" Bosch relay. Any help is appreciated.
