How to discharge a cap
scheisse87
I'm getting ready to install a new amp and have been told by many that caps are worthless and actually hurt the performance of your system unless the electrical system is beefed up, which mine is not. I want to ditch my cap when I do the install of the new amp but am unsure how to properly do it, seeing how I didn't install it in the first place. Any help or suggestions would be much appreciated.
Throw it in a ditch or at a sign.....
I plan on it, but first I need to figure out how to "properly" uninstall it so I don't **** up my system even more. Can I just disconnect the wiring and then throw it in a ditch or is there some proper procedure that I have to follow?
Pull the main fuse from your system. Then turn power on from your HU. The amp will try to power up for a second from the charge left on the cap, and discharge it. It's then safe to remove it without fear of sparks.
A good quality capacitor is very efficient and poses virtually zero 'extra' load on an electrical system. If you already have one, I wouldn't remove it. It might not do much good but they really don't hurt anything.
You can discharge it by putting a resistor across the leads of the cap. But I would not listen to them and I would keep it. They do more good than harm.
the reason we suggest not getting a cap, is because its a *WASTE OF MONEY* seeing as you already wasted it. no sense throwing it away.
just keep it in there, but keep doubly sure of your alternator. if ti DOES break, get a higher powered one.
scheisse87
scheisse87
Dallas Tx
req
