How to connect this 4 speakers and 1 sub to a 4 channel amp and a HU?
hgomez809
Hi everyone,
I am kind of new to this and i am trying to figure out a way to connect all this together, i would appreciate if someone could help me.
--Speakers 4x = Crunch P1-653 6.5" 800W 3-Way Car Speakers
size/ type : 6.5" 3-way
impedance: 4-ohms
freq. responde: 59hz-20khz
sensitivity / spl: 89db
mounting depth: 2.13"
power handling: 800 w
RMS power: 55 w
-- Sub 1x = AUTOTEK ATX12D4
power handling: 350 w RMS and 700 w MAXX
impedance: 4+4 ohms
-- Amp 1x = KICKER ZX350.4 4 CHANNEL 350W AMP SPEAKER AMPLIFIER STEREO CLASS A/B ZX SERIES
RMS Wattage at 2 Ohm x 4 Channels: 90
RMS Wattage at 4 Ohm Bridged x 2 Channels: 175
RMS Wattage at 4 Ohm x 4 Channels: 60
Peak Wattage at 2 Ohm x 4 Channels: 180
Peak Wattage at 4 Ohm Bridged x 2 Channels: 350
Peak Wattage at 4 Ohm x 4 Channels: 120
Stable down to: 2 Ohms
Active Crossover: Low-Pass (Lp) 50 - 200 Hz, High-Pass (Hp) 50 - 200 Hz, Full (Ap)
Bass Remote Included: No
Channels: 4 Channel
Cooling Type: Heatsink
Power Ground: 4 Gauge
Design: Class a/B
Bass Boost: 0 - 18 Db
Signal-to-Noise Ratio: >95db, a-Weighted, Re: Rated Power
Dimensions (in): Length 13-1/2" X Width 9-5/8" X Height 2-1/8"
CEA-2006 Compliant: Yes
-- Head Unit (Stereo) 1x = BOSS AUDIO BV7280
Screen Size: 3.2
Monitor: YES
FM: 18
AM: 12
Total Preset Stations: 30
Switchable Radio Regions: USA, EUROPE, ASIA
Remote: YES
Body Mounting: Single DIN
USB: YES
SD Card: YES
A/V Input: Yes
Audio RCA Output: 2
Video RCA Output: 1
Subwoofer RCA Output: 1
CCD Camera Input: YES
Illuminated Controls: YES
Clock: YES
Preset Equalizer: YES
ID3 Tag: YES
Last Position Memory: YES
Separate Bass and Treble: YES
Balance and Fader Control: YES
Loudness: YES
Total Power Output: 320 Watts
Total Number of Channels: 4
Dimensions (H x L x W): 3.85" x 9.52" x 8.18"
You are going to have to run your front 2 channels at 80hz -> High pass (for example), then bridge your rear channels to your subwoofer and run the x-over were you want from 50-80 depending how punchy you want your bass.
run your front RCA from your HU to the front input on the amp, if your deck has a sub out run that to the rear channel input on your amplifier.
Easy peezy.
he's saying to use the front outputs of your 4ch amp to power speakers and then bridge the rear output to power the sub w/ a low pass turned on.
to give signal to the amp, use front rca out to front amp-input and then use subwoofer rca out to rear amp input
oh okay thanks but like how do i do that?
how do i connect all the speakers to the 2 front channels? and how do i bridge the two read ouput to power the sub? and how do i turn on the low pass??
& oh okay thanks
hgomez809
hgomez809
San Jose, Ca
jungstah
