How to connect 4 channel amplifier RCA cables with Alpine Imprint PXA-H100 ?
kknd99
Hello everybody,
This is my first post on this forum. I can call mysellf newbie in car audio and I have a lot to learn.
My setup is: Alpine CDA 117, Audison Voce AV K6 2 way with passive crossover, Audio REX 10s4 v.2 in sealed box and everything is connected to Kenwood KAC-X501F amplifier. I also have Alpine PXA-H100 processor that I would like to use.
My question is how to connect RCA cables when amplifier has only 2 pairs of RCA inputs and PXA-H100 has 3 pairs of outputs (Sub W, rear out, front out) ? Should I use only front out and sub out and leave rear out not connected?
you are building a 2 way system
Front output from processor to channels 1 & 2 on amp
Sub output from processor to channels 3 & 4 on amp
You will not be using the rear output on the processor at this stage
Thanks for reply. How about the switch on the processor x-over? Should I move it to FRONT/REAR/SUB position or leave it at 3WAY position (see first picture)?
Sent from my SM-N920T using Tapatalk
kknd99
kknd99
Chicago IL
kknd99
