how to bypass the alpine Iva 310?
The wire that goes to the brake pedal switch is looking for a + signal. The wire that goes to your parking brake is looking for a - signal. Hook the wire up like normal to your brake light pedal switch and hook the other wire to a switch and ground the switch. Does that make sense to you?
I believe you need the pac 7 or something.
or you can use two toggle switches. if i remember correctly, in order to get the video to play you have to hold down the regular brake, and then turn the e-brake on, off, then on again. so you can wire the brake pedal wire into the brake lights, or to a toggle switch with 12v, but IIRC again, you have to hold down the brake pedal to keep the video on screen, so youre better off using a toggle. then wire the e-brake wire into a toggle switch.
to bypass to watch movies while you drive, hold down the brake (or work the first toggle), then take the "e-brake" toggle switch and flip it three times (on, off, on).
double check the procedure with your owners manual, but i think that is correct.
Yeah this is right. You might as well hook the brake wire to the brake pedal switch. That makes it easier to operate that having to work 2 toggles. Hook the Ebrake wire to a one side of a toggle switch and ground the other side. That way when the switch is on that wire will see a ground signal. Then just use the procedure hoss mentioned and your good.
KustomKonceptz
KustomKonceptz
Houston TX
Pitchblack98
