How the hell is this possible?
zachzchw
I have a 97 bravada, same thing as a blazer/jimmy.
Sub setup is a pair of RE HC 12"s, powered by an IA 20.1 at .5
Ported, tuned to 32. Box is 3.6 cubes total, 45 sq. inches of port.
It has a switchable port, which would bring it up to 39 hz with 70 sq. inches of port.
Some kid down the street has a similiar truck, same year blazer. He has a pair of Type R's, and his shit is MUCH louder than mine........Not sure what amp/box he has, but it just doesnt seem right to me.....
Would the jump in tuning and port area have a huge effect or not? Anything else I could try?
I just dont see how the hell a pair of Alpines would be louder than a pair of HC's. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
He doenst have a **** TCAB........if I had to guess,
id say a prefab.......
One of those guys that buys everything at Best Buy....Im sure you know the type.
He doenst have a **** TCAB........if I had to guess, id say a prefab.......
Your install/box=even shittier than his? //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Even with it tuned at 39 with that much port...his still noticeably outpounds yours?
Your install/box=even shittier than his? //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gifEven with it tuned at 39 with that much port...his still noticeably outpounds yours?
Box is **** solid......build by inhumanacura/matt281, originally for a pair of RL-Ps.
Facing towards the rear, both subs and port.
I had some air leaks, from subs being put in and out so often.......put silicone around the subs today, so Ill see if that helps tomorrow.
Install is good- 1/0 to the amp for power and a ground, good ground, etc.
Dont know, but its buggin me.........its not like Im envious of his setup, I just wonder if mine isnt performing at its best........hmm.
Also, your box with those subs might have odd peaks in the response. If you have some t/s parameters, plug them into winisd, or I can do it for you if you have some specs.
I cant find specs......
Time to look harder, I guess.
Failing that, Ill call RE tomorrow.
zachzchw
zachzchw
ohio
UndercoverPunk
BP1Fanatic
BP1Fanatic
