How the **** do i figure out the volume of a triangle
Obviously i fail at math but im trying to figure out the volume of this triangle-ish box im working on designing. I think im going in the wrong direction here but i need about 7 cubes net, and a box no taller than 15 inches, has to be slant face as the subs are 15.5 inches wide. Im gonna attempt to do this myself but im having trouble planning everything out before i get the materials
Heres my max specs. I could go bigger but i wanna leave a little airspace around the box too.
15.5 inches tall
18 inches deep
55 inches wide (this is pushing the limits of my trunk, i have 60 inches of width in total, at the trunk opening)
heres what i got so far
If all else fails, build it, and fill it with packing materials.
Then empty the packing materials into a square or rectangular container.
Measure said packing materials.
Area of that triangle = (1/2)(12)(14) + (4)(14)
Multiply it by how many inches you want to extrude it and you'll get its volume in cubic inches.
Divide it by 12*12*12 to get cubic feet.
Just seperate it into two pieces...the rectangle on the right and the triangle on the left....then simply find the area of the rectangle and then just (height x width = y....then y/2 will get you the area of the triangle)...then add that to the rectangle's area and multiply it by your depth of the object for your volume //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I Like Waffle
North Carolina
bonesninja
