How much to repaint front end?
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gif U just have to wait a few weeks to see the changes.
or even days.
Ive had it for a year and it still looks as good as the day they painted it. definantly worth the $600. I have heard bad things about maaco though, I guess that there is a possibility that I got lucky, but who knows,
x2o, they are a bodyshop chain who paint for cheap. worth a shot...
http://maaco.com/StoreFinder.aspx?ZipCode=33025&x=17&y=11
hm, there's one pretty local (bout 20 minutes away) I'll give them a call tomorrow and see what they charge.
thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If you were to go with Maaco, I would definitely do the prep work yourself. It will leave less room for error on their part and all they have to do is spray it.
It really depends on what kind of work you want done. If you want it done for the cheap, Maaco is a good place to go.
But if I were you, I would do the prep work yourself like the person above me mentioned. Also, do the masking yourself - they got over spray on my WHEELS when I had them paint a few body panels that were oxidized all the way through. It cost me $300 to get the hood, roof, and a quarter panel painted with a one-step paint.
I doubt they would charge you over $200 for their three-step paint job (primer + paint + clear coat), and that paint job will honestly be just as good as the one from the factory.
i myself need to get my left fender and a new bumper painted, local i get quotes from 1200 up to 1600. rough estimates in the miami area are like 500-700. lol, soemtime early next year when i get my tax returns i'm taking it up to get painted. my only issue is i'd have to stay in a hotel or do something for the entire time of them painting the 2 parts. :/
This is probably your best bet, unless your friends with someone local that can spray. But check around and get some estimates.
When it comes to painting, the prep work is really what makes or breaks a paint job. You can have the most talent with a gun in your hand, but if your spraying something with little to no prep it just isn't going to work.
Spraying paint is really hit or miss. Maaco will be able to lay the paint down, but Maaco's downfall is simply just being lazy, because, well, you get what you pay for. Maaco puts minimal efforts into the prep work, resulting in a poor paint finish.
Also, dont get anything sprayed that isnt a three part process. And if you dont prep the painting surface right then the paint isnt going to adhere and your going to end up with paint falling off and a terrible paint job.
Prep the bumper yourself. Get some 400grit, pull any trim and moldings off, and scuff up all the paint and smooth out any chips or imperfections.
Take it down to Maaco, tell them you want it primed, painted and cleared. You can handle everything else. Even wet sanding and buffing if need be.
The only thing that leaves for them to **** up is laying the paint itself. Which could include runs, coverage, and how well laid out the clear is.
But, as long as the guy at Maaco has used a spray gun more than twice in his lifetime you should be fine, and if theres any issues thats what wet sanding is for.
If the bumper is in bad condition you're looking at around 200 quid (exc. supplies) in England.
So thats like 400 dollars in the US, maybe you're looking at a bit more.
That's for a professional job.
wow the prices you guys post make me glad that i can do alot of different things on my own or i'm willing to learn them....cuz 400 for a bumper painted..i do my whole car for less than that...and if its messed up i just sand it back down and start over again...when its done looks like a 1k-2k dollar paint job done in the garage of my house...
but if they have basecoat runs that cant be solved with wet sanding..
Nope.
If I was to run up to the paint supplier....
Base Coat (Quart)- ~$30
Reducer (Quart)- ~$20
Clear Coat (Quart)- ~$30
Activator- ~$20
Sand Paper, Measuring Cups, etc.... ~$20
So $120 tops for all the materials needed for spraying it. Of course thats assuming you have odds and ends on hand.
Double that and you could spray a whole car, outside.
//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
i've priced my paint scheme out already....
3 qts of red 60
gallon of clear and qt of activator 90
primer 30
reducer 3 qts 21
201
thats full car painted, wet sanded, and buffed....all door jams and complete engine bay.
i've priced my paint scheme out already....3 qts of red 60
primer 30
reducer 3 qts 21
201
Hells yeah. What brand paint?
I usually spray PPG //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
x2o
Fuzzy Blue Lights
x2o
Miami, FL
Denhsturrr
